Calculated mass column packging or maximun mass to inyecte
Hello
I would to know, how do you calculate maximun mass to inyected in HPLC column? or how do you calculate mass packaging of a HPLC column?
Thanks in advance!!!
There is no true upper limit of how much mass can be injected onto a column. It primarily depends on how much separation you are willing to sacrifice, as well as a few other things such as details on the running conditions.
Similarly, the "mass of packing" in a column depends on a lot of different things, most importantly the specific pore volume of the packing.
I assume that you want to do some preparative chromatography. If you give more details about what you want to do, better answers can be provided.
In total there are 32 users online :: 3 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 29 guests
