HPLC HP1090
Good afternoon! I started to work with used HP1090 which does not have proper manuals, and I have several questions. I did not find purge/prime system, so I just remove the column head to purge. Is there a purge system? How the injection system and the needle washed? Are they always connected to the flow? Is there some special procedure to wash the pump? I have some “pumpâ€
Pump Priming: http://www.chem.agilent.com/cpdocs/A258 ... N=97850354
Also - go here & search in Lib & Tech. Support for "1090 Manual" http://promosearch.atomz.com/search/pro ... sp10032a70
DR
Thank you very much! It was a great help! :)
Users browsing this forum: Google [Bot] and 12 guests
