integration of chromatogram
I am confusing in integration of peaks of a chromatogram. I got 2 peaks for a chiral compound, but not baseline separation. How can we integrate those two peaks (either insert peak or split peak). On what basis, we have to choose these integration. Please suggest me.
Thank you in advance
Can you sum the peaks together - not likely or you wouldn't be trying to separate using a chiral column. I'd say the answer depends upon how much separation/resolution you're getting. Can you post a chromatogram?
In total there are 21 users online :: 1 registered, 0 hidden and 20 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 20 guests
