As an aside, water elutes under the methanol on a DB-624. You don't see it (very well, see other posts) until you try to do this with an HID and then it is pretty obvious. So, in essence, you phase is buried under water all the while the methanol is coming off. Therefore, Rodney's advice about a short piece of PEG at the front is what I would try next, after changing concentrations or split ratios (both of which are easier to do than a PEG pre-column.)
Best regards.
