Temperature range for ACE 300 C4 phase
I am currently testing the 3 µm ACE 300 C4 RP. Unfortunately I wasn't able to find information about thermal stability for this particular phase. Can anyone comment on this? (I would like to run it routinely at 60 °C.)
Thanks in advance!
I've used this particular column at high temperature (55° C) once.
Just like all other silica based column materials it's stable at least up to 60° C. I wouldn't hesitate to apply even higher temperatures (e.g. 70° C).
I would recommend a temperature of 40C or less at pH 7-9, and would recommend a similar temperature range < 40C if working below pH 3 for best column lifetime.
Thomas J. Waeghe
MAC-MOD Analytical, Inc.
Chadds Ford, PA 19317
800-441-7508
twaeghe@mac-mod.com
www.mac-mod.com
OK, then I will stick to 40 °C. (Usually we analyze our samples at pH ~2.5)
Thanks!
In total there are 20 users online :: 1 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 19 guests
