TFA vs. Formic Acid
We sometime have unwanted blank peak when using formic acid in mobile phase, I was told that TFA is a better replacement for formic acid. Beside possible suppression of the MS signal do you have any other issues when using TFA?
Please share your experience.
yt
YT
Will you use formic acid at 99% pure? I use this and I have no "ghost" peaks. About the TFA, I think that it do not harm the MS signal. The only thing against the TFA is that during chromatography could Trifluoroacetyl some products.
TFA:
-Trifluoroacetic acid (TFA) is the simplest stable[1] perfluorinated carboxylic acid chemical compound, with the formula CF3CO2H.
- The use of trifluoroacetic acid in API-Electrospray may lead to the formation of ion pair with analytes and the consequence is ion suppression.
Formic Acid :
- Formic acid have a good volatility and is capable of lowering pH at value 2-3: therefore it is good choice in API-ES for compounds with a protonable group.
[url=http://www.hairhut.org.uk]Hair Clip[/url]
In total there are 14 users online :: 0 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 14 guests
