what is the best volatile buffer at neutral ph
thanks a lot if you can give me any suggestion.
I don't think there are any good volatile anions with pKa values near 7. On the cation side, if you can go up a bit (say, to the mid-7's) you would be on the ragged edge of the buffer range for ammonium, so something like ammonium formate or ammonium acetate might work.
thanks a lot.
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 24 guests
