Agilent system airlocked
left it pumping over the weekend, 0.2ml/min, 50/50
came in yesterday and system full of air, not sure how as there was enough solvent
how can I fix this?
TIA
What is the solvent you are using? If this happens to me I ususally prime the system again and then push isopropanol through (higher viscosity - helps to push air through).
cheers, I tried methanol and that seemed to work
one thing I notice was that the filter was releasing air bubbles, took this off then no more air
In total there are 28 users online :: 2 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 26 guests
