Analyzing PMIDA in water
Hi There
Any one who has experience with analyzing PMIDA (Gylphosate impurity) in water samples? LoD 0,1 ppm
Best regards
Breinbjerg
If HPLC is the method of choice I would start with a HILIC column.
Thanks - I'll try that.
Regards
Bo
Here is method for analysis of glyphosate and related products. Method is LC/MS compatible, so LOD/LOQ should satisfy your needs:
http://www.sielc.com/application_185.html
I am not sure that with UV or ELSD you can achieve detection limits of 0.1 ppm
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 24 guests
