Polymer vs Si columns, analysis of polymers
I am curious if there is an advantage in using a polymer (aphera from supelco) column instead of a silica based column (i.e. hypersil bds) for separating a pegylated molecule MW ~ 10K da.
The method utilizes C8 with ion pairing reagent ocante sulfate sodium salt.
I can't see how interaction between the polymer column and polymer molecule would have improved selectivity over a Si column.
Since silica columns have more substitution, more C8 groups, shouldn't it be more selective (i.e. higher plate count, more ion pairing) to use that with the ion pairing reagent?
MestizoJoe
Analytical Chemist and Adventurer
Venture Industries
Spider-Skull Island
What are you using for detection? One advantage of aphera and polymeric columns in general is that they have much better performance than silica columns by light scattering detectors, ie, better detection limits.
I am using UV detection.
Isn't the advantage you are talking about related only to the detector? Or are you trying to say that a polymeric column will have less peak broadening? That would certainly provide better resolution with related substances.
Could you clarify how the detector improves the columns performance?
MestizoJoe
Venture Industries
Spider-Skull Island
Yeah... I'm only talking about the detector. The claims that I have heard are that silica sheds off particles which result in poorer baselines with ELS detection. Whether this is true or not I do observe 10 to 100x lower baseline noise with polymeric vs silica materials with ELSD. No help to you hear I'm afraid.
Oh I see. Well that is good to know, anyway. Thank you.
MestizoJoe
Venture Industries
Spider-Skull Island
think about the totally different chemistry
Excel
In total there are 25 users online :: 1 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 24 guests
