When you did the earlier maintenance, and the recent column change, did you change the gold seal at the bottom of the inlet ? Tailing with a brand new column is very likely to be dirt somewhere in the inlet.
Also, when you installed the new column did you trim a few cm off the end after you threaded it though the ferrules ?
