Waters 510 pump remote control
Does anyone have either the pinout for the remote connector on a waters 510 pump, or the frequency/voltage range that is used to control the flow rate?
Scott Horn
Our 510 pumps are connected via Pump control modules to empower software for control.
The external control socket on the rear of the Pump has 6 pins mounted as shown:
1 4
2 5
3 6
The corresponding connection socket on the Pump Control Module only has 4 pins present, there are no pins present at positions 4 and 5.
I bought a supply of the sockets and connectors here http://www.mcmaster.com/#multipole-connectors/=ag3snk Socket part No 69695K84 in order to make up additional cables.
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
In total there are 45 users online :: 1 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 44 guests
