continuously stirred mobile phase.
In the USP monograph for griseofulvin, it calls for the continuous stirring of a mixture of three miscible solvents (thf, acn, and water).
Why would stirring help?
Thanks, I'm just curious.
MestizoJoe
Analytical Chemist and Adventurer
Venture Industries
Spider-Skull Island
Does USP stand for Unbelievably Sucky Procedures ?
Unintelligible Standard Practices ?
Unnatural Substandard Protocols ?
Most likely originator of the assay procedure stirred his mobile phase, so it was retained. OK: why? Likely when the monograph was written there was not online ternary or quaternary mixing, so such mobile phases were pre-mixed and pumped from one reservoir. User likely felt that stirring either kept it relatively uniform in regards to preferential evaporation through venting, or used stirring/heat/vacuum to keep the mixture from absorbing gases (before in-line vacuum degassers). Many, many USP procedures are woefully out of date.
I agree with Consumer Products Guy. When I was doing HPLC method development in pharmaceutical industry, 95% off all USP methods did not work. It seams that nowadays it is still the same. Don't worry and just use your online degasser.
Users browsing this forum: Google [Bot] and 10 guests
