Peaks not seen by ELSD
I'd really appreciate your feedback. I have two polyols with almost identical boiling points (ca. 295 C). One elutes at an RT of ca. 11 min with OK ELSD signal as well as UV signal), the other elutes at ca. 7 min with OK UV signal but without an ELSD signal using ca, 75:25 to 80:20 (ACN:water) on a non RP column. Can you explain why I'm not seeing a peak for both and only for one using ELSD?
Thanks very much, Ninus
For "oils" ELSD sensitivity smallest UV sensitivity for diens .
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
