Storing Deuterium and Tungsten lamps
Hello. The projected lifetime of our deuterium lamp is 1000hours and the tungsten lamp is 2,500 hours.
I was told that these lamps can not be bought and stored. Unfortunately it takes a very long time to get consumables to the lab.
I would like to know long in advance they can be bought?
Thanks!!!
Tungsten lamps should have a pretty long shelf life. D2 lamps - not as long. These should be ordered shorlty before they will be used to get optimal life from them. Also - order them from suppliers who do not keep large inventories of them around. If it takes a long time to get one, this strategy will be particularly helpful. If a D2 lamp is 3-6 months old before you get your hands on it, you're probably OK. If it's a year or more on receipt, it's time to look for a new vendor and/or refine the timing your ordering.
DR
Thanks DR for the timeframe.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
