Acetonitrile elution
I am working with a small peptide (1.3KDa). I am following some literature to purify it in Sep-pak C18 column. Everything is kind of straightforward but I do not have a lyophiliser (we are not a chemistry lab). So I was wondering, the elution protocol from the paper suggests 50% acetonitrile:50% water for elution. If I would use 100% acetonitrile for elution and then use a vaccum evaporator to evaoparate the Acetonitrile from my peptide, would that work, or any reasons that this cannot work? This way I should not have the issue of having the water left over after the vaccum evaporator.
Any suggestions are welcomed. Thanks, konkon
You can certainly try it. Possible issues to watch out for:
Is your peptide soluble in 100% ACN?
Will 100% ACN elute additional impurities?
Thank you for the comment. I suppose I could use 50:50 to do the first purification, back dilute the acetonitrile concentration, rebind and elute with 100%. Not sure if the peptide is soluble at 100% but does it really matter if I am going to evaporate the acetonitrile later on?
Thank you.
Yes, because it has do dissolve in the ACN in order to be eluted from the cartridge. A small peptide *should* be soluble in ACN, but "just because I'm paranoid doesn't mean that the world is *not* out to get me." :wink: !
