application method for Cannabinoids by GCMS
We are using Shimadzu GCMS2010 to measure cannabinoids. Does anybody has the analytical instrument method to compare with our method since our results are not so good.
Are you trying to follow a published method? If so what kind of problem are you having? The make of mass spectrometer should not be an issue unless you are tring to use a quadropole instrument where something like a sector instrument is requried.
Users browsing this forum: Google [Bot] and 1 guest
