Mobile phase buffers for LC/MS
What mobile phases are people using other than ammonium acetate, acetic acid, and formic acid that are compatible with LC/MS?
What do you use if you want a pH that's in between acid and neutral?
ammonium acetate and pray.
can try also ammonium formate (buffer range- 2.8-4.8)
Ammonium bicarbonate for basic pH.
