Transfer line
Does anybody know where to source a transfer line for connecting a 6890GC to a Varian 320MS?
Why ? A 320 MS if supplied originally would have had a Varian GC, there was no option for an Agilent. If you choose to modify another GC to fit the 320 it should work fine using the contact closure start but there is no alternative transfer line available. Note the 320 MS is designed with an interface to the LHS of a GC , so you will be unlikely to find it easy as the 6890 is designed for interface from the RHS and you will most likely find circuit boards in the way. You could run with the MS and GC running facing different directions but it seems a lot of effort when you should have a Varian GC that you can use ?
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 5 guests
