ECD oil
How to remove the oil hydrocarbon signal suppression on ECD for PCB analysis?
Thanks.
Send me your email address and I will send you an application. My email is dshelly@unitedchem.com
Don
Don Shelly
Don Shelly Consulting, LLC
don.shelly@donshellyconsulting.com
Hi Faulagnier; I used to follow an ASTM Method for this; we used concentrated Sulfuric acid for the reduction of carbonil groups in the oil. Take the oil and add concentrated sulfuric acid and sheke for 5 mimnutes (Be Carefull!!) remove the H2SO4, add fresh and repited a couple of time. Sulfuric Acid is going to reduce carbonyl and other polar groups that can give signal on ECD (Nice principle!); after that you do a clean up with Florysil cartridges.
Unfortunately I don't rave the exact ASTM reference on hand so probably what I am telling not be so usefull but any way; this used to work fine for very dirty oil samples.
In total there are 22 users online :: 1 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 21 guests
