high pressure
hi,everybody! I am using varian 320 prep,last time I find that the system pressure was too high,about 1600psi at 80ml/min ,but when I disconnect the lines between the column and the detector ,I found that the system pressure did decrease at 990psi,I do believe that somethong wrong with the detector , in fact ,I think that my detector was blocked ,if it is the trueth ,what can I do next?
Dear moon704520,
You must evaluate all probable points. Did you use buffers in you system?
What is the normal pressure of your system?
Have good elutions!!!
Carlos Teixeira
Carlos Teixeira
Users browsing this forum: Bing [Bot], Semrush [Bot] and 4 guests
