DNPH derivitization of trace LMW carboxylic acids
Hello all,
I am trying to design a workflow to measure concentrations of photorespiratory intermediates in seawater (eg. glycolic, glyoxylic, malic, formic, oxalic, succinic, citric, isocitric, cis-aconitic acids). Environmental concentrations will probably be low nanomolar to even picomolar so SPE or other pre-concentration as well as exclusion of competing inorganic salts will be needed. 2,4-dinitrophenylhydrazine hydrochloride (DNPH) will be the derivitizing agent in the presence of 1-ethyl-3-(3-dimethylaminopropyl)-carbodiimide hydrochloride as a coupling agent. The solvent will be buffered acetone with ion-pairing using tetrabutylammonium hydroxide and tetradecyltrimethylammonium bromide for the counter ions, pH adjusted to 4.5 with phosphoric acid. I want to measure the hydrazones with absorption around 380 to 400nm. I am looking to select appropriate columns for these hydrazone derivatives keeping sensitivity in mind. Unfortunately many of the available resources for this assay are severely outdated. I'm a rookie so I would really appreciate some suggestions or even an alternative assay. Thanks in advance!
Best,
John
sorry, this was meant for the liquid chromatography forum.
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 25 guests
