aceton 0.05%
Hi all,
some one can tel me why we use aceton 0.05% for HPLC gradient autovalidation? (I am using shimatzu HPLC).
and can I substitute water by MeOH (I have some dificulties to pass the test using aceton 0.05%/water).
thank you.
Acetone is unretained, and it has a UV signal.
If "gradient autovalidation" is a test of pump and gradient proportioning valves then fact that acetone is unretained may be neglected, because test is executed with pressure restrictor instead of column.
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
