Thiol Standards GC/MS
Hello all,
I have been searching for a gc/ms standard of thiol esters (which includes methyl mercaptan, ethyl mercaptan, etc). Restek said they did not have the proper ventilation to make a custom standard that included all the chemicals I am interested in. What is another good place to look?
Thank you.
I'm confused about the term you use. Methyl mercaptan and ethyl mercaptan are esters? The sulfur compounds standard is a gas mixture, not liquid mixture.
m.finnBMBM,
JI2002 raises a good point about the methyl mercaptan being a gas.
You might try ISGAS or DCG out of Houston. Either of them can probably provide what you are interested in.
Best regards,
AICMM
Thank you. I've sent out some inquiries. I am also having trouble figuring out how to find these compounds in a sample. I want to see if there is any methyl mercaptan in a sample that contains a lot of methanol. What would be the best way to see if there are any mercaptans present? SPE, methylene chloride extraction? All under very cold conditions, of course.
Users browsing this forum: Semrush [Bot] and 23 guests
