Very simple question; but at the same time annoying..Grammer
This is a very simple question really, but I cannot find the answer anywhere...
If, lets say I am using an LC with a triple quadrupole detector: is the correct abbreviation i) LC-MS/MS ii) LC-MS-MS iii) LCMS iv)LC/MS ???
What is the difference between using a '-'or a '/' to separate two instruments?
Similarly, lets say I am using OFFLINE SPE, then I analyse the samples by LC with UV detection; is the correct abbreviation i)SPE-LC-UV ii) SPE, LC-UV iii) SPE/LC-UV
Does the use of a 'comma' between instruments suggest SPE is offline whereas the '-' suggest is online?
Thankyou for your help.
Haha. I believe what you are going to find is that this is not such a simple question. I can foresee many different opinions. However, the way you presented it gives a good light to how you should be seeing it.
You will see GC/MS and GC-MS all over literature, and even GCMS. They are both in use, so I do not think you can definately say one is right and one is wrong. That is a matter of conjecture at this point. The way I learned it is that you use the "/" to represent interfaces, or inline set-ups.
However, in your example with SPE, one technique is offline. It is completely logical that you should make a distinction to offline vs. inline. Therefore writing SPE-GC/MS would indicate this very well. As long as you are consitent you should be OK. This help?
grammar
I've always gone with the convention that an interface between two different technologies is a "hyphenated method", ergo LC-MS, and LC-MS/MS. But SPE-LC-UV (not that SPE is necessarily interfaced to the LC but that seems acceptable too).
In total there are 39 users online :: 1 registered, 0 hidden and 38 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 38 guests
