HPLC analysis - Retention time of a API and its salt form
Dear all
In HPLC analysis will the Base and Its salt form of a API have the Same RT or different RT. Eg. Omeprazole and Omeprazole Magnesium with these two have same RT during HPLC run or different RT.
Pl. advice
it will be same
it will be same
then how do i differentiate or know in a blind sample ( placebo mixture containing either omeprazole or omeprazole Magnesium) whether it has omeprazole mag. or Omeprazole.
Measure Mg++
You need to quantify both counter-ions and calculate content of free base and salt. Actually you molecule is basic and Mg ion is basic. Is it part of formulation?
You can do both using reversed-phase cation-exchange column. You will need ELSD/CAD for Mg determination:
http://www.sielc.com/upload/file/pdf/SI ... y_2009.pdf
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
Users browsing this forum: Semrush [Bot] and 10 guests
