What's the problem with these TICs?
17 posts Page 2 of 2
Seeni,
I don't know the thermo software (yet - I'm starting to use a MAT 95, so that will change), but the GC/MS software I've encountered from tohter vendors allows you to set some kind of detection threshold - and changing that should allow for more or fewer peaks to be found. And, once you have found many peaks, there should be a way of selecting specific target compunds for reporting. So, you should be able to find many compunds in a mixture and then report relative concentrations for a selected list.
Again if you need TIC information and you do not have a way to get it out of your software, I know you can get it out of AMDIS. It has reporting and target analysis capabilities. Worst case it will get you almost all the way there and you take a list of peaks and deconvoluted areas to a spreadsheet to get relative percents.
You will have to do some exploring. But, it will get you to wonderful places you never dreamed of.
Good luck.
Don
Dear Don,
Thanks a lot for your valuable input. I got it now. the thing is i have worked with standard concentration of 25 ppb. When i injected 1 ppm all peaks are there in the TIC. Thank you.
Seeni
In total there are 4 users online :: 2 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
