Re: How should I correctly report this?
Posted: Wed Nov 01, 2023 12:36 pm
vmu, if 100% derivatization efficiency is verified, please provide data to prove it for the problem raised by pear.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
I don't know what and how Pear derivatizes. I guess he/she verified 100 % reaction yield in order to use a commercial derivate as the calibration standard in his/her particular method.vmu, if 100% derivatization efficiency is verified, please provide data to prove it for the problem raised by pear.
Code: Select all
y = ax + bCode: Select all
Signal = Response * conc + BlankCode: Select all
Signal = (recovery * pure-Response) * conc + BlankCode: Select all
conc = (Signal - Blank) / (recovery * pure-Response)Code: Select all
net-Signal = (Signal - Blank)Code: Select all
conc = net-Signal / Response
