Chemstation A.10.01 CD
42 posts Page 2 of 3
I can supply replacement media copy of A.10.02 Chemstation, reasonable, since you're already a licensed user. You'd need to use your existing license number. Also A.09.03, A.08.03, A.07.01, A.06.03, A.05, and A.03.
If interested, post your E-mail address and country, and I'll contact you and ask you to make a reasonable offer.
I have a HP 1050 HPLC System with A.05.01 Chemstation installed. However, the computer is too old and I need to upgrade it.
Then, I would have to buy a A.10.xx version in order to install on a Windows XP Operating System.
Anyone can help me?
Lucas
Lucas - as above, post your E-mail address. I've got A.10.02 and can supply replacement media on a CD disk. You'd use your existing 10-character license number. I'd like to limit to USA and Canada.
My email address is lucasknana@hotmail.com
Thank you for your quick reply.
Lucas.
Lucas - I E-mailed you.
Hi again,
I did not receive your email.
Could you please email me again?
Use both email adresses please:
lucasgustinellisilva@gmail.com
Thanks again,
Lucas.
You are right; I checked my sent mail and it didn't go through. So I sent again to both E-mail addresses, and this time it showed in my Sent Mail box. Sorry !
I received the email now. I already answered you email and I'm waiting for your reply.
I appreciate your help,
Lucas.
Hi lucas,
Check your E-mail. I've uploaded it for you.
cheers
Hi lucas,
cheers
Good morning,
Thank you so much for sharing the files with me. That was very helpful.
I have a doubt and maybe you could help me:
The modules of my HP 1050 are not in the files of the setup installation. What do I have to do?
Thanks again,
Lucas
I think you should continue setup and go for configuration. there, you can select your instrument.
Lucas - I'm glad someone was more computer-knowledgeable than me (that's almost everyone) and could upload for you.
Continue the installation, go into Configuration Editor and you'll want to add modular system. Each 1050 module must be added individually then, and each module will have its own HPIB or GPIB code or address (this can be determined using the keyboard, easier than trying to re-set on an internal circuit board). Default addresses are listed on the Agilent website, maybe in the PDF installation manual.
The computer CPU itself needs a HPIB/GPIB board like 82341 or 82350 type (follow Agilent instructions for that, like coding as "hp82341" even if using part 82350), but I hear there's some USB way to connect as well. With HPIB or GPIB you'll also need to use such cable between that GPIB board on computer and a module, then link the other modules with GPIB cables and remote cables.
The information for Lucas was already uploaded by a friendly contributor here, so
I remember Emily Litella!
I really appreciate your help. Now I just got the GPIB 82350B from China and I´ll assembly my equipment.
I´ll take some pictures and upload here. I need help for connecting the cables. I´ll do that tonight.
Thank you so much.
Hello all,
I click into the install icon, then I add the LC Chemstation and it´s license number. Then I click OK. Then I click on Install and the screen automatically closes and nothing else happens.
Could you help me please.
My OS is Windows XP Pro SP3.
Wait.
Thanks all.
Lucas.
I could use a copy of A.10. Have licence codes, but disk is long gone. Need to reinstall as the drive is failing. any help appreciated. bob@terpenescience.com
Hi.
I am looking for the software for Agilent G1315B DAD and G1311A QuatPump. It is Agilent 1100 Series HPLC.
It requires G2170BA license
Agilent 32-Bit ChemStation for 2D Liquid Chromatography (LC) systems (G2170BA)
https://www.agilent.com/cs/library/spec ... 5055EN.pdf
Can anyone help?
Thank you.
Mykeil
