Formic Acid on an Agilent HP-5 Column?
18 posts Page 2 of 2
Life is chemistry and chemistry can be a pain. Everything else is commentary.
I liked that so much I posted it on Facebook. Thanks again Rod.
Incitor Inc.
"Making renewable fuels a reality"
http://www.incitor.com
Formic acid will have no response on FID, so you need to use PDD or TCD
Analysis is possible on thickest film PDMS, You can use 7 microns Rtx-1 on 0.53mm
jaap de zeeuw, Restek corporation
I used to do both formic and acetic by HPLC on a Hypercarb column using UV detection. I believe the eluent was 0.1% phosphoric acid.
