GC and MS no signal collected !!!@@
17 posts Page 2 of 2
BLESS YOU JAMES BALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Our runs were bombing the instant the start signal set off the run.
The log error was GC and MS no data collected.
In a million years I wouldn't have believed the remote cable would die. Just as you stated. Everything clean and dry. Both ends screwed down securely.
The cable looks like it is brand new. I had a spare cable, read your post and tried the cable.
I told my tech that there was no way that the cable was what was wrong.
THANK YOU THANK YOU THANK YOU
I'm glad to see that you solved it, but I will just chime in and say that my 5975 has the same issue pop up occasionally, and power cycling it seems to always fix it.
Users browsing this forum: Bing [Bot] and 5 guests
