Going from SW8260C to EPA524 or dual operation?
18 posts Page 2 of 2
That is a weird memory leak. I have that on my 5890/5971 GCMS Win95 Chemstation A.03.00. I always process data on my D.02 machine because using Data Analysis on the Win95 machine eats up a chunk of memory each time its used and finally Top crashes.
I remember that too. The Win 3.11 version had very little problems, but the W95 was more buggy. I also remember needing to reload the whole chemstation software at least once a year on W95, at least once we got the CD version it was much faster :)
For Chemstation E.02.01 do you know if an HP Compaq 4000 Pro or 6005 Pro small form factor PC is sufficient. Or do I need a newer generation of PC?
I have ran it on I believe a Pentium 4, maybe older so it should run on just about anything with W7 or XP. It is more stable on XP though. I have no idea how it will run on W10.
