Help with Agilent Macros
38 posts Page 2 of 3
consumer products guy
your macro look very interesting to me
is there a way to get it?
cheers
see viewtopic.php?t=10909
Is there any way for me to get a copy of that macro book?
mjcongleton@yahoo.com
TIA
bonaparte
I have a macro manual in pdf format, if you give your email I'll send it to you
Sergio
I'd like to write macros for report customisation too. Wondering if you could also send me the manual please. My email is HT2047@gmail.com. Many many thanks.
Sergio
Could I talk you into sending me a copy of the macro manual also. My email address is kevin.kramer@osbi.ok.gov, thank you in advance for your time and help.
Kevin
Dear Sergio,
I would very much appreciate if you could send me tbe Agilent Macros Guide PDF, as this would help me out tremendously to learn to automate what normally takes me many hours to perform. If ever I can help you in the future I will gladly!
Thanks so much,
Carvone
flavourist@gmail.com
Greetings!
I am starting from scratch in trying to write some Agilent GC/MS ChemStation macros (I have minimal programming experience). I have the Agilent Macro Guide, but I am still having some difficulty. Can anyone suggest a similar programming language/resource that might be useful? C++ or C Systems?? I cannot find any other reference materials or even classes available through Agilent or otherwise.
Thank you so much!
In the latest versions of ChemStation, the macro manual is included. Click on Help in the menu bar, then click on 'Commands' and then on 'Macros'. You will see 'Macro Programming Guide'. This is the macro manual.
Gasman
Keywords: UV-vis, Macro Programming Guide
Publication Number: G1116-90012
Last Updated: 10/28/2009
Number of Pages: 290
http://www.chem.agilent.com/Library/use ... gGuide.pdf
I know tat this list is getting long but I am at the point where I need to do a few things with macros as well.
Would you include me on your distribution list?
Dirk
dhunt@cytovance.com
Having worked as a consultant for Agilent in the past, I'd be glad to help any of you with your macros.
Email is josh.brewer76 at yahoo.com or at gmail.com
The language is very similar VB with some similarities to C (++), the key is knowing the variables the software uses and hooking them into the system without causing problems...
Josh Brewer
I've got it doing what I need it to now, but I will keep you in mind
Sergio
Sergio, I'm not certain if you still check these forums but I've sent you an email. I would like a copy of this manual as well.
Or if anyone else who has already received this manual wants to simply forward the pdf from Sergio, that would be appreciated as well.
Thanks.
Just a warning - for LC Chemstation the macro language changed dramatically for the current version B.04.02 - so much so that we did not upgrade to this version on our systems running macros. Before you code your macro using old manuals, be sure there haven't been any changes. Good luck.
Hi people!
I would like a copy also.
My e-mail is vitulich@inti.gob.ar
I too would like a copy of that macro book if you wouldn't mind. Please email me at ty.lahren@gmail.com. Thanks
~Ty~
