New column bad results
33 posts Page 3 of 3
Mix equal molar quantities of H3PO4 and NaH2PO4. This will give a pH around 3.1. Then, add NaOH solution dropwise until you get to pH 3.5.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
Phosphate wouldn't be feasable at pH 3.5 (pKa1 phosphate = ca. 2.2)
In that case acetate would be my suggestion.
Right; I meant 2.1, not 3.1. As for buffering at 3.5, formate's pKa is 3.7 while acetate's is 4.7. It would probably be better to start with unbuffered formic acid in water and add NaOH or NH4OH until you get to pH 3.5.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
