low pressure solvent chcek valve
Am looking for a solvent check valve to fit onto a teflon line [ 1/8 th inch ] that will prevent solvents from going back to the mobile phase bottle when priming a pump that sits low compared to the mobile phase container .
All help gratefully accepted.
C.Tony Vella Royal British Legion
WWW.HPLCworks.net
858.663 751
Arte et Marte
Apparently something like this exists in standard online fitting style housings,
https://www.chromtech.com/inline-check-valves
though I must say, I would think any kind of flow restriction on solvent lines would be undesirable, especially with low hydraulic head.
Found a check valve that will do this admirably.
WWW.HPLCworks.net
858.663 751
Arte et Marte
