Interesting experiment with Nitrogen Carrier
I decided to revisit Nitrogen carrier in GC/MS since the Helium prices are rising quite quickly now.
I came across an interesting problem. Scanning from 35m/z to 550m/z for normal Semivolatile analysis I have a major background interference of 42m/z. I have tried everything to figure out what that might be, and the only thing I have come up with is N3. Is that even possible?
Why not?
Presumably, can get scheme below if electron energy 70 eV is above IP of nitrogen.
N2 + e => N2+. and 2e
N2+. + N2 ==> N3+ + N.
N. + N. ==> N2
Also, do you see any [M + N3]+ type adducts?
JMB
Why not?
N. + N. ==> N2
JMB
Haven't looked for any above that yet, and had to switch back to Helium for normal samples, but should switch back soon for more testing.
The example I found had double bonds between the nitrogens or a double bond and two single bonds to the third in a cyclic arrangement. It has been found as a product within a reaction but in a vacuum with high energy electrons flying around who knows what crazy things can happen. Just thought it was odd that Shimadzu didn't mention it in their presentation I found online and supposedly they were scanning down to m/z 35.
The chromatography actually looks pretty good though you have to keep the flow very slow.
Users browsing this forum: Google [Bot] and 2 guests
