monolith validation
Has anyone tried to validate a monolithic column for the USP or FDA? Could you please tell me what difficulties and trials you had to go through?
Thanks!
~blaise5669
Why would you think that the method validation process is any different when using monolith column?
I don't really think that the procedure itself is that much different, but most of the approved methods I've reviewed don't include monoliths, and I was just wondering if anyone had had any trouble.
Thanks!
~blaise5669
I would suggest the following method:
Just do all the tests you would do with any other column and the results will show whether or not the monolith presents a special case.
And it might help remembering, that validation is not a test of a hypothesis but documentation of what you know (i.e. you’ve done the relevant tests – at least informally - prior to documenting the knowledge you posses).
Users browsing this forum: Bing [Bot] and 11 guests
