how does temperature affect resolution, retention, and time?
for gc how does temperature affect resolution, retention factor, and total analysis time
imo, the lower temp would increase total analysis time because everything takes longer to boil/heat up and to elute
futhermore since a lower temp is longer analysis time then retention would also be higher since the dead time marker would stay consistent but tr would be more
and for resolution i would say higher temperature lowers resolution? but i dont have good reasoning why and how
is there anything im missing for any of these?
thx
The other factor is that different molecules can have different relationships between retention and temperature, which means that the relative spacing of the peaks can change with temperature.
Users browsing this forum: Semrush [Bot] and 2 guests
