Solvent Tubing Nuts / Ferrules
Posted: Tue Dec 10, 2019 10:38 pm
Hello, can anyone help me with the parts / tools needed to make these terminal connections?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
Correct, these are your standard low pressure tubes. I have a couple ends that got cut off and was hoping to replaces the two connectors. If the solution is new tubing I can do that.Those look like typical low pressure fittings, can just purchase complete tubes with the ends on from chromatography suppliers...like tubes to and from a degasser.
To me, looks like the metal sleeve inserted on the tube, then plastic end piece pressed into the tubing, then metal sleeve moved over to hold the end fitting in place.
Those are actually the Lite Touch fittings from Upchurch( I think they are owned by IDEXX now). The metal ring compresses the outside of the vespel flangless fitting to compress it against the tubing. They also make them for standard 1/16" tubing in the high pressure flow path. I have always had good luck with those, and unlike metal fittings they can be reused if you are careful.Those look like typical low pressure fittings, can just purchase complete tubes with the ends on from chromatography suppliers...like tubes to and from a degasser.
