Choosing HPLC system. HELP.
Preparative HPLC system is needed.
Objects: nucleoside phosphates (100-500 g).
Could you give me a piece of advice about all the stuff (coloumns, detectors, pumps, etc.) i need.
thank you in advance.
Dear farynaaa:
Try to contact major vendors/suppliers, and ask for leads.
They may recommend a specific model, or a competing brand. Ask for sale brochure/press release.
farynaaa,
do you have any kind of chromatography method?
in TLC or HPLC?
this is you bases for deciding what is best for you.
you might be able to do what you need with a low to medium pressure system with flash columns, it might be by far less expensive then HPLC.
but you need to have a basis of knowledge based on what you currently do
Below are nucleotides separated on Unison UK-Amino:
Cyclic mononucleotides: http://www.imtakt.com/TecInfo/TI454E.pdf
Coenzymes: http://www.imtakt.com/TecInfo/TI449E.pdf
Adenosine phosphates: http://www.imtakt.com/TecInfo/TI448E.pdf
Sugar phosphates: http://www.imtakt.com/TecInfo/TI446E.pdf
The separation is done under normal phase conditions with
TEAA buffer (volatile).
In total there are 17 users online :: 0 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 17 guests
