Menthol by HPLC??
Hi Everyone,
I would like to know if anyone has analyzed menthol by HPLC using a UV-VIS detector. And before anyone suggests: I do not have a GC nor do I have an RI detector for the HPLC. :D
As far as I know, menthol isn't absorbed in the UV-VIS range, but I wanted to know if anyone has maybe modified a method so that a UV-VIS detector can be used. If not, has anyone assayed menthol using a spectrophotometer maybe instead?
I need to assay menthol as a raw material as well as in some cosmetic formulations. Any suggestions would be greatly appreciated!
1. You can try to obtaine UV absobing menthol derivate ( for example esterification with suitable acid anhydride )
2. Try indirect detection.
Good luck!
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 15 guests
