uECD signal increase
Hi.
Thats my problem.
During the sequence suddenly the signal in uECD increase.
Sometimes one injection is on 300 Hz and next incjection running in 500 Hz.
Sometimes the signal suddenly increase from 300 to 500 Hz during the one incection/analysis.
Its shows in attached chromatograms.
Code: Select all
http://s000.tinyupload.com/?file_id=03294320583173885096
Code: Select all
http://s000.tinyupload.com/?file_id=09155856303246386258
I replace: ferrule from the detector side, ferrule from the injector side, column, liner, septa, traps on hel and nitrogen.
Where is the problem? Does anyone have an idea what is going on?
My GC: Agilent 6890N
Thank you for any help, tips.
Frank
Hi.
Thats my problem.
Code: Select all
Code: Select all
Frank
Did you replace the large ferrule on the makeup gas fitting to detector? We have had those crack before and leak as the oven temperature ramps up, or just give erratic readings.
Also the liner inside the makeup gas fitting can break or become contaminated and cause problems.
