Help with upgrading to Millennium3.2
Posted: Tue Mar 17, 2009 3:56 pm
I have a Waters 600 running on old Millennium Workstation Version 3.05.x. I want to add a 996 PDA and also upgrade to 3.2 with Millennium Workstation Version 3.2 Upgrade Version which includes a Master Option Key Disk (Step 1) and 3.2 CD (step 2).
The Disk label says:
Step1:
Follow the steps in the Pre-Upgrade Tasks section in the Upgrading from Millennium Chromatography Manager Version 3.0x to Version 3.2 procedure (P/N 716000446).
Insert and use this Master Option Key Disk Exactly as instructed in the Pre-Upgrade Task section
Step 2: upgrade to version 3.2
Caution: Run 3.2 CD only after completing the Pre-Upgrade Tasks as described in Step 1. If you failed to complete Step 1 prior to Step 2, you will invalidate you software options disks. .....
Follow the steps in the Upgrade Process section of the Upgrading from Millennium Chromatography Manager Version 3.0x to Version 3.2 procedure (P/N 716000446) to install the Millennium Version 3.2 upgrade.
I can not find the procedure sheet (P/N 716000446). Can anyone help with this and email me the instruction? Thank you very much in advance.
Step1:
