sled error / purge error
Posted: Fri Mar 27, 2020 2:12 pm
Recently we had some issues with our autosampler CP-8400 of our Varian CP3800. We had the "sled error and the purge error".
So the technician came and replaced the autosampler. But now we still have it.
Could it be a problem with the electronics?
As we have installed 2 columns recently, so there has been worked in the place where all the cables are coming together?
Something that I noticed in the manual is that we should do once in a while an auto calibration of the EFC. If I do that, it says that is failed. What should I do?
Can this be the reason of the errors? What exactly does this calibration does?
Kind regards
Kind regards
