Problem with GC-MS with hydrogen
Posted: Wed Apr 15, 2020 8:19 pm
Hi to all, I work with an Agilent GC-MS and recently i have changed gas carrier from helium to hydrogen.
Agilent technician has already performed PMOQ.
But today i have found a problem with filter (trap) --> if I use the filter the N2 is high, if i bypass the filter H2O is high.
Another problem is that all the compound peaks with hydrogen has different retention time despite with helium --> someone knows how to do an analysis in scan with opelab2?
thanks in advance
thanks in advance
