temperature and baseline
Posted: Fri Apr 17, 2020 11:24 am
Dear colleagues,
I have some issue with baseline. While temperature program is isothermal I observe increasing baseline. When the ramps starts baseline goes down and it is the same until run ends. Here you can see it on this picture. Have you any ideas what could I do to prevent baseline increasing at the begining of the run?
The temperature is 60°C until 4.5 minutes. Maximum temperature is 260°C. Blue line is from ECD and red one from FPD.
