Peak height vs peak area
Posted: Wed Apr 29, 2020 12:05 pm
Hi all!
I am measuring ethanol with gc and my sample is strong liquor. It is prepared by pipetting 2 ml of strong liquor into a 20 ml volumetric flask and adding 0,4 ml of n-propanol. The flask is filled up to the mark with water. The n-propanol is added as internal standard and its final volume is 2 %.
The concentrations of my calibration solutions are 1 %, 2 %, 3 %, 4 % and 5 % (the solute is ethanol). In each of these solutions 2 % of n-propanol is added as internal standard. As a result, I get peak areas of ethanol and n-propanol. To calculate concentration of the sample i divide area of ethanol with area of propanol of each calibration solution and plot them on a curve. The ratio between area of ethanol and area of propanol of the sample is placed on the graph and the concentration can be calculated.
My question is, my instruction tells me to calculate the concentration using also the peak heights. I only know the height of the sample (peaks of ethanol and n-propanol). Do I need to calculate the peak heights of the calibration solutions using peak areas of calibration solutions as well to get to the concentration?
Any help will be appreciated!
