Pulsed flame photometric detector (PFPD) sensitive low
Posted: Thu Apr 30, 2020 3:24 am
Hello, Does anyone know how to fix the PFPD detectors?
I use PFPD with Agilent 7890B. The PFPD signal suddenly decreased. When you injected sulfur species compounds, some of the peaks disappeared and some of the peak signals are very low and broad. Like H2S and COS peak disappeared and DMS broad peak. The photometric tube works fine. The carrier flow rate Air 40 mL/min, H2 50 mL/min and make up N2 is 5mL/min. If the N2 flow is too high, the PFPD cannot be ignited.
