Peak Purity
Can someone explain to me how peak purity is calculated?
Go to waters website.....check out there online libary...you will have to register to do this....you will get all the info you need there
Agilent has an alternative approach to assigning peak purities as well.
Both methods essentially look for any differences in the changes across the UV spectrum at either end of a given peak or they compare either end to the middle of the peak, the assumption being that if there are two different substances nearly co-eluting, they will have at least slightly different UV spectra, so you look for these differences.
DR
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 26 guests
