Clearing a Shimadzu SIL-30 fatal error message
Hello everyone,
The other day I got a SIL HPV ERR HOME message on the autosampler of our HPLC. I got some suggestions on how to fix it, however, the control panel on the door is completely unreactive as the error message is displayed, nothing can be changed.
I was wondering if there is a way to clear the error message (maybe a combination of keys to be pressed), so that I can access the menu.
Thank you for your suggestions!
if you can connect via web-interface to the Shimadzu controller, you will be able to clear the error from there
Thanks for your answer,
Unfortuantely I don't have access to the web interface. In fact, I am working on a Sciex LC-MS system, but the LC part is actually a Shimadzu instrument painted with a different color...
Today I have contacted the service technician, who of course wants to change the HPV rotor assembly for a fortune. I am almost certain that a cleaning would be enough, however, currently I have the needle in the HPV and I don't have clear access to it and I cannot remove the needle because the fatal display on the autosampler is stuck on the error message and doesnt want to let me access any of the menu options.
I only worked with Shimadzu/Sciex, not Excion/Sciex, so pardon my ignorance
does it mean that unlike Shimadzu, Exion LC does not have a separate controller, even though it is connected via LAN? if it does, then the controller should be accessible via browser when the hardware profile is not activated; why would Sciex change anything besides the color of the panels?
also, when you power off the autosampler, it may unlock the drives so you could move the arm manually
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
